Results 1 to 20 of 21
Thread: High Pressure Pump Start Angle table with aftermarket fuel pump lobes?
    May 2020
    5
    When using a cam with an oversize fuel pump lobe are people adjusting the fuel pump start angle table? Seems like if I understand how things work it would take less start angle when the stroke is increased by an oversized fuel pump lobe.
    Oct 2018
    43
    I believe you edit the row axis on the leading edge angle. Multiply whatever percent fuel lobe you have to the entire row. This will edit both leading and trailing edge angles.
    2016 Silverado CCSB L83/6l80e
    TSP cam 218/226, .635"/.635", 113 LSA 10% FL
    TSP LT headers
    Circle D Billet converter
    Dec 2018
    Dallas Texas
    35
    Quote Originally Posted by SILV View Post
    Could you share a little more about the leading edge angle? I'm not seeing it anywhere in the tune.
    Aug 2009
    Calibrating
    3,371
    Under fuel system tab
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2020
    5
    This is the table I am talking about. It seems to me that the table would need some sort of update based on a factor related to the fuel pump lobe. I don't see much in the scanner related to the pump control though.
    Aug 2009
    Calibrating
    3,371
    That tables does need to be calibrated for larger cam lobe, info came from an OEM calibrator to do so
    14 Gen 5 Viper
    Oct 2018
    43
    Quote Originally Posted by DanLeeWatson View Post
    Yes that's the table. I dont know your application but it looks like the row has already been modified.
    TSP LT headers
    May 2020
    5
    So how do I go about doing that with HPTuners? I don't see much in the way of pump channels in the scanner.
    You just update/edit the row axis values to reflect the percentage of increase in the pump’s output volume.
    Click on the row axis title to edit it.
    May 2020
    5
    Quote Originally Posted by crankz1 View Post
    How are you determining the pumps new output volume? are you just assuming it is the same as the % called out on the fuel pump lobe?
    Yes. Like SILV said above.
    May 2020
    5
    Ok, but how are people verifying this actually works properly? I can't find anything in the scanner that shows error or correction for pump pressure. I would think this table is the primary means to correct under and overshoot in the rail pressure but I never see it talked about.
    Apr 2007
    330
    When I put in my 32% fuel lobe I never really noticed many fuel pressure issues, it appeared the commanded and desired behaved like stock. Anyway I multiplied the entire row axis by my new fuel lobe cam value (1.32) like SLIV said. I didn't notice any difference though but I feel better that its now "fixed" at least.
    I have a 38% fuel lobe and previously was using the stock Leading Edge Angle settings. In an attempt to reduce pressure spikes when quickly transitioning from high fuel demand to low fuel demand, I modified this the fuel volume axis. In my case, it messed up the fuel trims at idle where no matter what I changed, I couldn't get them dialed back in (20%+ error at idle). I tried multiplying by 1.38. I also tried an interpolated multiplier from 1 to 1.38 at the highest flow. Each test resulted in seemingly uncorrectable fueling. If I change it back to stock, it's fine. If I multiply by a lesser value, say 1.10, it introduces a smaller amount of error. Whether the table is modified or unmodified, the rail pressures stay really close to commanded (aside from the spikes when fuel demand rapidly drops).
    Has anyone experienced this? I have no idea why this messes up fueling, but it does in my application (2017 Camaro ZL1 M6).
    Any ideas on reducing momentary rail pressure spikes (5,000+ psi) with a large fuel lobe?
    Advanced Tuner GapRider's Avatar
    Nov 2015
    South Carolina
    246
    Quote Originally Posted by travislambert View Post
    I hope it's OK if I jump in with a question also because I'll soon install a cam with larger fuel lobes. (I know it's an old thread)
    Fundamentally, the larger fuel lobe strokes the positive displacement HPFP more, so it pumps more fuel, and it is fixed to the engine RPM (unless I'm missing something) - so the pump creates the pressure; my question is, what relieves the pressure to maintain desired pressure? It doesn't make sense to me that it would just be fuel injectors to relieve pressure because they need to deliver the rate of fuel the engine needs, which is different than the amount of fuel pressure needed to be relieved to control fuel pressure. So how is pressure controlled?
    2019 C7 Stingray M7 - long tube headers, 6.30/6.22 226/238 cam, supporting stuff, DOD and VVT delete.
    Stock everything else
    Jun 2022
    Did you ever figure this out? I am seeing the same exact thing with a 38% lobe. When I lift off after a pull I am seeing spikes of 4000-5000psi. Is this acceptable? Or is there a fix?
    One thing that was never mentioned in this thread was the pump type. You should start with the stock leading edge table that the HPFP in use was designed for. If running a LT1 hpfp pump, then you need to start with a LT1 table. If running a LT4 pump, then you need the LT4 table. If running a LPE big bore, you need to use the LT1 table. Then you multiply the row axis buy the fuel lobe percentage. I only mention this because many have upgraded from a LT1 hpfp to a LT4 or LPE. Or went from a LT4 to LPE. So, you need to make sure to start with the correct base table then modify it per the fuel lobe percent.
    Baltimore, Md
    1,204
    Did the guys having spike problems and not seeing expected results with this table, find that they were starting with wrong table? Or still doing the odd stuff regardless?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    May 2003
    South FL
    1,359
    Starting with the wrong data in the angle table and then multiplying the axis by the fuel lobe can cause excessive spikes.
    [email protected]
    Owner/GM Calibrator
    Baltimore, Md
    1,204
    LT4 pump supposedly, lt4 injectors, cam with 34% lobe on it, with all the LT4 info in it and axis mult by 34% Im still seeing a spike after letting off from commanded 2600psi to @4000psi? This is on that car with the weak power in other thread
