Results 1 to 5 of 5
Thread: Base fuel table question - spanish oak
    When I change the values in the base fuel table which says it is for open loop operation there doesn't seem to be any change in my logs.
    I went so far as to set it at .7 lambda. But when I log WOT "open loop" there is no change in indicated lambda. It will always reads around .880 then slowly ramps up to around .910 as the rpm increases.
    Am I missing a fuel table or calculation someplace?? The only thing I can think to do at this point is change the inj slope. I am targeting around .850 but can't get it there.
    MAF is dialed in. Trims are good.. I'm stuck.
    EDIT: I'm using the stock widebands. Its a flex fuel car and came stock with dual widebands. I have also replaced them but the readings remain the same.
    Feb 2018
    Kuwait
    98
    Try to make the changes in the fuel base cold table.
    Ok I'll give that a try. Thanks!
    Thanks that was the right direction! Got the afr to hover around 12.75 to 12.50 using those tables so thanks for the direction!
    Feb 2018
    Kuwait
    98
    Glad to hear it worked with you
