Results 1 to 2 of 2
Thread: L61 / E37 Standalone Questions
    Tuner in Training DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    18
    Hi all,
    I am working on a stand alone application of an L61 with an E37, both from the same 2007 Pontiac Pursuit / G5.
    First the tough question that might make everything else moot:
    E37 Tach Output. Is there such a thing? Should I stop now and get an E67 ECU instead?
    If we get past that:
    I have an Innovate wideband O2 - can this be wired into the ECU?
    1972 Triumph Spitfire Ecotec Swap
    MEFI-4B & L61 - deceased; ate it's own balance shafts - because I did a dumb.
    E37 & GenII L61 - Runs great! (extracted from an '07 Pontiac Pursuit / G5)
    LSJ for the future..?
    Aug 2012
    40
    No tach output on E37. Tach is driven 1 of 3 ways. Can buss tach, with tach driver module sensing coil voltage dip, off of alternator ac tap. Questions, Give me a call. Steve 909 910 3867
