Looks like my STIT in p/n is around .12 and in gearis .22 I think I want to be closer to zero. My LTIT stays at .07 anyone have any good info where to go from here?
2001 Camaro SS A4
Chris posted this a few days ago.
Originally Posted by Chris@HPTuners
1982 GMC S15 5.3 4L80e
1954 Corvette ls swap in progress
right, so say at 180* my stit is .12, and ltit is .07 So I would ADD .19 to my base running airflow vs ect at 180* right???
2001 Camaro SS A4
Good question OZ, maybe someone can elaborate more on the above post.
The explanation is good, just not how to make the right changes ie actual values with an example.
1998 Z28 Red/Gray HT, A4, 3.23
|Pacesetter, Hooker ORYP, Aerochamber|TSP Cam, PRC dual valve spring kit, LS2 timing chain|LS6 oil pump,|SLP Air Lid, P&P TB, FRA, TBB|Fuddle 3400 2.1, B&M cooler|GM iridium plugs, Taylor 8 mm|AMW catch can|J&M PHB & LCA's|HPTuners 2.1|HP House & Dyno Shop
ttt up up up
yeah I'm gonna add this into my "tuning for dummies" write-up once I get the DEFINITE answer.
2001 Camaro SS A4
Originally Posted by ozorowsky
I am doing this today at lunch... I will let you know how it goes...
Just installed new cam (F13 Futral), 230/232 .595/587 112lsa +4, and it idles pretty good right out of the box.... very suprised....
2007 CTS-V LS2
Originally Posted by SideStep
I just logged my idle from start-up to 192* degrees (f). Idle is set to 900rpms after 154* ECT
ECT Average (roughly) Combined STIT and LTIT
90-155 -.09
155ish 0
155-192 .1
??? This seems to be pretty damn close right out of the box??? The car does idle fine though...
Any thoughts...?
My only concern at the moment is the rpms do not fall as fast as I would like. Would this be fixed by adjusting the "Throttle Follower Decay"? It does not hang ... or hunt/roam for idle.....
2007 CTS-V LS2
I just started playing with this last night and my LTIT was .07 and STIT was 0 so I just applied +.07 to everything in the base airflow table and then started logging it again and I was seeing a good correction (about -.06 STIT, the LTIT were still +.07) so it seems to work. After driving it around for about a half hour I noticed that it was still a little unsettled but I just left it alone and I'll get a couple days or normal driving on it before I mess with it again.
I wasn't having any idle problems except sometimes the idle would dip when coming to a hard stop with you pushed the clutch in to early. I did notice the car seems to start better this morning, like it lit right off. Could that be from messing with this table?
-Mike-
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
11.301 @ 129 1.68 60' MT DRs
11.85 @ 124 1.90 60' street tires
well I tried messing with it a little tonight, and I must say I am very discouraged. my LTIT is at -.40 and my STIT is at -.02 while in gear at idle. So I went ahead and subtracted .4 from 177* an up. Nothing happened...I even let the car sit in gear at idle for 15 minutes, to see if the LTIT would move. It did actually go to -.39 but remained there indefinatley. It seems that no matter what changes I make wether they be postive or negative , have an effect on my LTIT's. Right now my car idles great in park and it even settles into a nice little idle in drive once it has been sitting for 3 or 4 seconds. But it sure sucks donkey balls when it's time to come to a stop. The only way I can keep it from surging is by tapping the brake pedel to build up some vacum.
For us Noobs that dont know all the terminology, whats LTIT and STIT?
Dixit
2002 Z06 AFR205cc, Crane 228/232 .600" 112LSA Cam, MAMO-fied FAST intake, MAMO-fied LS2 90mm TB, Kooks LT 1.75" Headers, Magnaflow Xpipe to Straight Pipes, Blackwing Intake. And then about $5k in audio/video
Originally Posted by Dixit
LTIT = Long Term Idle Trim
STIT = Short Term Idle Trim
2007 CTS-V LS2
Ok I finally figured out why I was having problems...Hopefully the rest of you have not been dumbassess like me. Mine was actually way off. I was showing -.4 LTIT. I then tried to correct for this by subtracting -.4 from the corresponding ECT in the table. However I was not noticing a very good correction. In fact it was hardly moving my trims at all. So I decided to look into it a little further. After 3 days of this crap it finally hit me in the face. The scanner is reporting in lb/min however the IA vs Cool table is setup in g/sec. You have to convert it over to g/sec. So instead of subtracting -.4 I should have been subtracting -3.03!!!!!!!!!
Hopefully none of you have been making the same mistake, or if you have you can learn from mine.
FWIW, my table was so far off that I had a real hard time getting the car to start after making such a drastic change to the IA vs Coolant table, due to the fact that the car was still using the old trim. I actually had to hold down the throttle a slight bit to get the car to start then let off very very lightly. The idle would then bounce up and down quite a bit, then the car would die. However after 3 or 4 starts, it finally stablized itself. It took a good 20 minutes of idle relearn procedures, but my trims are now resting at or near 0. Good luck guys, and remember:
YOU CAN NOT MAKE A 1:1 CHANGE OF WHAT YOU ARE SEEING IN THE SCANNER. YOU MUST CONVERT YOU VALUES IN THE SCANNER FROM LB/MIN TO G/SEC.
Originally Posted by WS6snake-eater
Damit!!! I did the same thing.... I am using your advice now....
: I feel like a noob.....
2007 CTS-V LS2
Sure hope it works out for you.
LOL, time to go make some corrections to mine. I was starting to wonder why they didn't seem to change much. Good find ...YOU CAN NOT MAKE A 1:1 CHANGE OF WHAT YOU ARE SEEING IN THE SCANNER. YOU MUST CONVERT YOU VALUES IN THE SCANNER FROM LB/MIN TO G/SEC.
-Mike-
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Thanks for the above info. The LTIT on my car was pegged at -3.0 with STIT ~ -.4 so I changed base running airflow in two steps. In other words I added 1/2 of LTIT+STIT to the base airflow. Worked well.Originally Posted by WS6snake-eater
I also just finished logging LTIT/STIT data while turning on and off the low/high fans via Scanner and the AC manually. As soon as I crunch the numbers I'll have a better airflow numbers for those accessories.
Is the MAF being used to target the base running airflow? Just wondering 'cause I get offsets when logging various flow rates along side of the LTIT/STIT and base flow data. I havent calibrated the MAF yet, after MAF calibration, will I need to retune base airflow?
2000 M6 SS Convertible, FTRA, Lid, LS6 intake, LS6 S heads, TR220, RT cats, Magnaflow, paint chips on pass side door.
I just tried it and yes it did.....
.. have to laugh at myself :
2007 CTS-V LS2
Well I just about got it nailed down...I'm going to use the above suggestion, and disable the fans when I start it up this afternoon to get some better numbers for in gear. I've got park dead nuts on. After I nail down the in gear with no fans, I will re-enable them one at a time and see how much they offset. From there I can enter those values into the fan offset tables. This is some pretty good stuff!
How does the VCM look at the idle base running airflow temperature? ie, does the 20C column get used for all ECT between 10C-30C or from 20C-40C? Does it interpolate?
