The "STFT OPEN LOOP" tab effects?
The STFT OPEN LOOP tab that is is found under:
Engine_Fuel_Open Loop/Base on the left side
I understand it applies the learned STFT to the final PW calc when in open loop, but does it also apply this same correction to PE,WOT,Accell fueling modes?
If it does, I would "assume" that the STFT cells that would not be populated due to never being in closed loop when they are "visited" would be 0 and the correction for those cells would stay 0. Does that sound correct?
Thanx guys! Always appreciate the insight.
