Results 1 to 10 of 10
Thread: Edelbrock 2300 boost is crazy
    Orr Z06 new tensioner.hpl
    Can someone possibly point me in the right direction? I have tried different pullies, and new tensioner to see if the boost will hold steady. The boost gets goofy around 52 to 54k rpm on every log.
    Not sure what else could cause the issue. I am going to pull the spark plugs and close the gap a little but I am starting to think its the design of the blower.
    This is on a 2016 Corvette Z06.
    I have also clamped the bypass valve closed and still does the same thing.
    Jul 2012
    Florida
    1,459
    Looks like belt slip
    2013 Silverado 5.3, 6L80k 8.8
    Oct 2017
    Charlotte NC
    101
    To me it looks like Torque Management pulling timing and closing the Throttle therefore much less boost.
    For Example,
    Pull 1 @ 4220 RPM
    Boost drops to 3 psi, TM Adv :22, Commanded Throttle Actuator : 45%, Predicted Axle Torque Source : Chassis
    Pull 1 @ 5100 RPM
    Boost drops to 5 psi, TM Adv 13, Commanded Throttle Actuator 68%, Predicted Axle Torque Source : Chassis
    Maybe the 2nd pull is similar.
    Dec 2018
    Washington State
    182
    Belt slip, mine does the same thing, if i ease into it i can hit 14 psi, if I stab it the boost goes up then drops to 3 psi.
    I know the TQ MGT pulls when traction is going off.
    It is most likely belt slip. I put the shortest belt on their I could squeeze on it. I had to put the belt in a pan of boiling water to stretch it just enough.
    The tensioner is just 1/8'' from maxed out area. I am running a Gates greet Fleetrunner. Is their another popular belt to try maybe? Id like to make a idler but the supercharger should not have that much slip unless its just too much parasitic loss??
    Jul 2012
    Florida
    1,459
    Are you spinning the tires and having to pedal it?
    your TB is not staying open. log more trq parameters
    Oct 2017
    Charlotte NC
    101
    Quote Originally Posted by str8dum1 View Post
    That's what I was saying too.
    Is it feasible to turn off TM for testing and if so what do I do with it to turn it off?
