Results 1 to 7 of 7
Thread: Fuel gauge reading backwards after tank/ pump swap
    Feb 2019
    10
    I swapped my 2001 gmc fuel tank for a 05+ tank for the larger fuel bucket to run my dual pumps. my issue is my fuel gauge is reading backwards now and i cant figure out what to switch in my tune for it to read properly? i looked at a tune for a 05+ truck but i cant see whats different. any help is great thank you!
    7,613
    Swap the two sender wires at the pump module. The '01 gauge is expecting to see 250 ohms full/40 ohms empty, '05 reads 40 ohms full/250 ohms empty. This is not something you can 'fix' in the tune.
    7,613
    Wait, no... that won't work. Stupid me. It'll still be the same ohms with the float in the same position.
    If you could mount the sender card upside down, that would work. Well, it would give you the right electrical output.
    At least the gauge is accurate at 1/2 a tank.
    Feb 2019
    10
    my buddy told me to flip the markings on the actual gauge lol
    Feb 2019
    10
    im just going what the guys on the truck forum do when they swap the tanks, they say it can be changed in the tune so idk lol.
    Feb 2019
    10
    So i was able to fix it in the tune. i went under "Primary Volume" under the Fuel system tab and basically flipped the values.
