Results 1 to 20 of 20
Thread: E38 Throttle Response Adjustments - Desired Throttle Area Table
    Jan 2020
    27
    Hi all, after a ton of reading - I am still a bit confused on adjusting these tables.
    The stock C6 LS3 I have (6l80e) has the below 0-9% Throttle zeroed out and starts with 1 at 15%.
    See Below:
    Is there a way to adjust this to get a little more response down low? Similar to what a Peddal Commander would do.
    I notice the ZR1 base tune has 1 starting at 9%
    I am assuming this would be the right area to do so, but know I cant change things too much.
    Anyone modify these tables want to share a screenshot?
    never done it myself but yeah go for it. ive heard you just need to maintain a smooth ramp. I don't think you'd mess up by shifting the table to the left 1 or 2. worse thing you don't like it and put it back.
    Australia
    1,986
    read the info at the bottom of the page when ur cursor is on that table tab, get it wrong and its not good so most just do small changes if any
    Add some decimal places to your table, you probably find that those are not all zeros.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
    Jan 2004
    Perth - Western Australia
    278
    I generally use the tables to restrict power on blown cars.
    Comes in very handy with PD blower cars if they are over-pulley'd or experience belt slip in higher rpm's. Restrict it opening in the mid range then let it eat as the rpm's get up.
    As an example, I have a 416ci & harrop fdfi2650 combo in 1 of my cars, for testing purposes @ full pedal to the floor. I have it set to 23% @ & below 2400rpm moving up to 43% in the 100APP column. Car is still QAF, but still makes 10psi of boost vs 18 & still makes 600+whp.
    Jan 2020
    27
    For whoever is curious down the line - After a few different tests, I added the following changes to Tables A B and C.
    End Result:
    Feels a lot better!
    Aug 2009
    Calibrating
    3,376
    I mod this table on almost every car... BuT some will put you in REP instantly
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jan 2020
    27
    Haven't had issues in a few hundred miles.
    Safe to go higher based on what you do? I've been enjoying the changes so far.
    Aug 2009
    Calibrating
    3,376
    I don’t want to disclose what I do to them on an open forum.. but yes you can
    14 Gen 5 Viper
    Aug 2018
    294
    Glad to see some others that actually use this table to their benefit. Makes a wonderful difference in the dead area in the first bit of pedal travel, in my opinion.
    how far did you end up going? i keep playing with my Throttle Area maps and get into REP and a p0606 when i go too far...but haven't found the limit yet
    ~Ryan
    Apr 2024
    I was successful in using HPTuner and applying the above configuration to my 2014 Camaro 1Le. I wrote to all 3 tables, and immediately afterwards, the dreaded "dead pedal" was gone. More so, and to my extreme delight, My camaro was very responsive in all driving conditions. If you have not done this, then this is a game changer for sure. Lastly, you do not need the pedal commander.
    Many, Thanks.
    Apr 2023
    31
    Same for me, the one time I tweaked the map to make it more linear, REP right away. (2012 Tahoe)
    Haven't messed with it since.. Something about TAC module programming?
    Aug 2021
    864
    Post #9. That guy there... You NEED to get ahold of him for throttle mapping!
    Aug 2009
    Calibrating
    3,376
    Quote Originally Posted by LS ROB View Post
    Thanks for the kind words
    14 Gen 5 Viper
    Feb 2020
    Metro Detroit Area
    267
    I've found, with a manual transmission messing with this setting makes it harder to feather the clutch when taking off from a stop. I didnt like it at all. It can be too responsive, at least IMO. I put mine back to stock. For those with automatic transmissions Im sure its great. Just not for me.
    Aug 2021
    864
    Quote Originally Posted by danmw2003 View Post
    I run a manual paired with a cammed ls7 and don't have any issues clutch feathering related. I have noticed that having fueling pretty much dead on will help with that.
    I used a Vitesse throttle peddle commander on my LS-2 E38 Corvette, which worked great, until I started using HP Tuners. After I removed the peddle commander, the car will not go into "ignition not start" mode.
    I tried removing battery from the car, as well as multiple start cycles, to no avail. At the risk of hijacking this thread, has this happened to anyone else? I'm unable to download anything into the ecm. The push button start switch works normally except for the "push start without pressing the brake peddle" to enter start but not crank mode. I looked all over the internet for any info and found nothing. Any help would be greatly appreciated!
    Jan 2004
    278
    have you tried doing a brake/clutch pedal relearn?
    I'm confused. I used to be able to push the start (green lit part with the circular arrow) without pressing the brake pedal for 5 seconds to get ignition hot, no start mode. Now it works only if I press the brake, then push the ACC / Stop side of the rocker switch for 5 seconds. Well it least I can get to Ign hot, no start mode so I can read and write to the ECM/TCM and clear codes. Thanks to Digital corvette forum for showing me that work around. I'd love to know what changed though.
