Results 1 to 11 of 11
Thread: E38 Throttle Response Adjustments - Desired Throttle Area Table
    Jan 2020
    27
    Hi all, after a ton of reading - I am still a bit confused on adjusting these tables.
    The stock C6 LS3 I have (6l80e) has the below 0-9% Throttle zeroed out and starts with 1 at 15%.
    See Below:
    Is there a way to adjust this to get a little more response down low? Similar to what a Peddal Commander would do.
    I notice the ZR1 base tune has 1 starting at 9%
    I am assuming this would be the right area to do so, but know I cant change things too much.
    Anyone modify these tables want to share a screenshot?
    never done it myself but yeah go for it. ive heard you just need to maintain a smooth ramp. I don't think you'd mess up by shifting the table to the left 1 or 2. worse thing you don't like it and put it back.
    Australia
    1,984
    read the info at the bottom of the page when ur cursor is on that table tab, get it wrong and its not good so most just do small changes if any
    Add some decimal places to your table, you probably find that those are not all zeros.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
    Jan 2004
    Perth - Western Australia
    276
    I generally use the tables to restrict power on blown cars.
    Comes in very handy with PD blower cars if they are over-pulley'd or experience belt slip in higher rpm's. Restrict it opening in the mid range then let it eat as the rpm's get up.
    As an example, I have a 416ci & harrop fdfi2650 combo in 1 of my cars, for testing purposes @ full pedal to the floor. I have it set to 23% @ & below 2400rpm moving up to 43% in the 100APP column. Car is still QAF, but still makes 10psi of boost vs 18 & still makes 600+whp.
    Jan 2020
    27
    For whoever is curious down the line - After a few different tests, I added the following changes to Tables A B and C.
    End Result:
    Feels a lot better!
    Aug 2009
    Calibrating
    3,373
    I mod this table on almost every car... BuT some will put you in REP instantly
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jan 2020
    27
    Haven't had issues in a few hundred miles.
    Safe to go higher based on what you do? I've been enjoying the changes so far.
    Aug 2009
    Calibrating
    3,373
    I don’t want to disclose what I do to them on an open forum.. but yes you can
    14 Gen 5 Viper
    Aug 2018
    294
    Glad to see some others that actually use this table to their benefit. Makes a wonderful difference in the dead area in the first bit of pedal travel, in my opinion.
    how far did you end up going? i keep playing with my Throttle Area maps and get into REP and a p0606 when i go too far...but haven't found the limit yet
    ~Ryan
