Results 1 to 2 of 2
Thread: Vehicle does not start while vats set to "none"
    I Swapped a 5.3 lm7 into my 2000 tahoe z71 obs, i cranked it and it started right up and shut off, i used the hptuners to set the vats setting to "none" then clicked "write entire" and security light turned off and now truck wont start, i did this about 5 times and still wont start, i set the vats to serial again then it starts right up and security light starts flashing again. Any advice? been at this for the past three days
    13,565
    Vats disable only requires a write calibration only on those computers. That should be all that is required to turn it off. You can check for other DTC's related to the anti theft system and set them to no error reported.
