Results 1 to 3 of 3
Thread: help with start up after engine warm
    so the issue i am having is that after the engine warms up it doesnt want to fire when i crank even if i let the pump complete its prime cycle befor i crank, no matter how long i crank. occasionally it it will give a burp of a fire up but wont fire. but if i let the pump prime again it will fire right up!
    Where should i make my adjustment to get it to fire the first try cranking?
    Feb 2019
    Lodi, CA
    174
    What would be handy is to see your logs and a list of mods. Haven't really given us much to go off of. The tune helps, but tells us nothing more than what it is and what it is trying to do, but a log will tell us what it's actually DOING.
    what pids would you recomend? i have redone all my log pids so there is a lot of them removed from the original hp log set up
