Results 1 to 3 of 3
Thread: Trans shifts at 2x the commanded speed and RPM.
    Feb 2014
    5
    I installed a 4L80 trans out of a 99 dually in my 05 GTO a few years back. It was shifting perfect in both normal driving and under WOT for at least 2 years. I removed the trans to install a new engine in the car this past winter and ever since then the trans will not shift under WOT. I have checked all the wiring, replaced the speed sensor at the rear of the trans. and still nothing.
    Playing with the tune I found figured out that if I reduce everything (Speed and Throttle) by 50% it would shift. Example 1-2 shift set at 18 mph @ 5500 actually shifts at 42 mph @ 6700
    I did some searching but came up dry. Any guesses?
    See attached
    Aug 2009
    Calibrating
    3,373
    I’ve seen this before and I believe the speed sensors needed to be swapped
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Feb 2014
    5
    I replaced the rear sensor with a new unit last week as well. I'm not using the front sensor. It was working fine without it wired up for about 2 years.
