My car idles pretty well i just have an issue when the car gets hotter or mostly when the IATs are real high it will just keep wanting to pull idle airflow.
It will pull desired airflow down to high 6 g/s in gear and 4s in park.
The other thing i noticed is when shifting into park or into drive the rpms will jump as the pcm commands 10.5 g/s that the tune wants, then hang for a few seconds and come down as the IAC closes and brings the airflow down.
Now common sense tells me that the BRAF is to high but before the IATs get so high the idle trims are not bad amd i dont get that hanging idle. And i no way will my cam want 6g/s at idle when dynamic is closer to 15-16g/s.
Also thinking it may have to do with IAC vs Effective area as my dynamic airflow never matches my desired. The iac vs eff may be off causing issue?
Im not near my laptop but mods are in sig.
