Results 1 to 9 of 9
Thread: JTEC 4.0 Injector Scaling?
    May 2020
    45
    Hey guys...
    So on the '98 JTEC 4.0 ecu, there isn't much there for altering injector size. I've seen some threads talking about adjusting battery voltage correction... I've seen another talking about scaling the entire fuel map by the percentage difference between the stock injectors and the replacements.
    For instance.. the stock injectors are rated at 243.8 cc/min (23.2lb @43.5psi) and the replacements are rated at 363.1cc/min (34.6lb @ 43.5psi). That equates to a 48.93% increase.
    So.. if scaling the whole map.. would I multiply the whole map by .5107?
    Or is there a better way to do this?
    Thanks guys.
    Apr 2014
    704
    Quote Originally Posted by Mr4btTahoe View Post
    Hey guys...
    Thanks guys.
    Use the inverse of the injector increase.
    363.1/243.8 = 1.4893
    1/1.4893 = .6715
    Multiply fuel map by .6715
    And, yes, you need to alter batter voltage offset to match the new injectors, or the whole map will be off.
    All of this, of course, is assuming the only thing changed was injectors. If there were other changes made (ie. MAP sensor range, base fuel pressure), then the whole stock mapping is thrown out and you basically start from scratch.
    May 2020
    45
    Already tuning for the 2 bar map... Just starting to run out of injector.
    So.. where do I get the battery voltage offset info? The injectors I'm using are coming from another car.. low mileage grand Prix gtp. They are plug and play as far as size and such goes... But they are just a stock injector. So far, I've only had luck finding flow rates I posted above.
    Thanks for the insight.
    Nov 2017
    816
    From the calibration of a GTP file would be the only place - if it happens to be in the same format. And it probably won't be.
    So your choices are to purchase injectors that you can get data for or say fuck it and dial it in as close as you can with pulse-widths without changing the battery offset. And possibly have issues.
    Apr 2014
    704
    An injector P/N would be needed to have any hope of finding that data. Or, at least the make/model and year that these injectors came from, then getting the corresponding tune file for said vehicle to look up what the GM calibration had them defined as. Even then, assuming they were originally calibrated as 3 bar injectors, and are now running in a 4 bar setup, it'll be a bit of guess work getting them defined close enough.
    May 2020
    45
    Hmm...
    The injectors are a Bosch # 024508208 also referred to as the "Bosch Whites"
    I've found some numbers but not sure yet.
    Apr 2014
    704
    Hmm...
    What are the breakpoints for voltage that are shown in your calibration file?
    May 2020
    9
    Mr4btTahoe
    I would love to see one of your tune files on tuning the 2 bar map. Im working on my 97 2.5 turbo and having some issues
    May 2020
    45
    Quote Originally Posted by MSJeepTJ View Post
    Mr4btTahoe
    My other post describes most of what I did.. I'm at work now but can post the current file when I get home.
