Thread: aem wideband 4110 convert to lambda
    can someone help me convert my aem uego 4110 to read lambda in the scanner. Right now i have it set to read afr. I had to double the stoich method for my E40 ecu because i am running 72lb injectors. I have been trying to figure it out for days with no luck. Thanks guys
    cam only 136k plus mile ls2 longblock supercharged gto 11.1@126 1/4 mile on 8psi
    13,533
    Can you right click the channel to change the units?
    I tried that last night but its a no go. I cant change it. Only thing it allows me to do is change decimal points.
    anyone?
