Results 1 to 9 of 9
Thread: 2016 camaro ss e85 tune
    Jun 2020
    Ohio
    4
    I am having trouble after doing a e85 tune, getting codes p0171 p0174 lean, is theere something i am missing on my tune? Does anyone have the correct numbers to change on my tune, i think the stoich numbers are wrong. Thank you
    311
    Did you add a sensor??
    May 2003
    South FL
    1,369
    post your tune
    [email protected]
    Owner/GM Calibrator
    Nov 2009
    All Around
    3,149
    ^ what he said
    Jun 2020
    Ohio
    4
    Quote Originally Posted by Jonblarc7 View Post
    yes added sensor and wired to #38, changed everything in hp tuners with sensor but didn't change the stoich or timing? didn't know what numbers to put in there.
    Jun 2020
    Ohio
    4
    Hello, I can post the tune when I get home from work. Thank you
    Jun 2020
    Ohio
    4
    Here is my numbers for stoich, do I need to change them to 9.85? my numbers across the board are 14.10840 under alcohol composition? I cant find a way to post the entire tune on website. Thank you for any help I can get. also spark smoothing says disabled is this correct?
    13,564
    A stoich table that is using E85 will be sloped. It's going to start at 14.68 at 0% and go down to 8.9 at 100%.
    So find a stock flex fuel stoich table and paste that in there.
    Copy the stoich table from my trucks tune and it will work.
    Jul 2020
    7
    I have a 2017 SS and all the e85 tables are populated. I turned everything on just waiting for my sensor kit. Are the prefilled tables close or way off? Would i just adjust the afr table to make it linear or is there more that needs adjusting? Stock car but want to run e85
