Page 1 of 5 12345 LastLast
Results 1 to 20 of 100
Thread: Ecoboost Mustang dummy check
    Jun 2019
    Wisconsin
    295
    So, not really new to tuning, but fairly new to tuning torque based ECMs, mostly just experience with some older ME7 VW/Audi stuff... Otherwise it was really old Nissan ECCS and Megasquit 1.
    Anyway, I've just started working on my 2015 Mustang and just looking for a sanity check to make sure I'm on the right track.
    I'm looking to bump boost, basically trying to get back to the power that the Ford Performance tune gives (since I can't read that as a starting point), I wanted to work on opening the tune up for my catback exhaust (still on stock because of overboost trip when using the FP tune) and bumping the idle RPM for oil burn issues with said catback.
    Looking at the log, I did a few short pulls, builds about 18-20PSI no problem, then at the 7:53:38.114 mark it hits 22.3PSI, which triggers FMEM overboost.
    Given the MCT and RPM, I'm guessing that I'm hitting the LSPI load limit?
    Appears to fall right in the hi/normal table at 2.18/2.15 load and the log is showing 2.173, so is that indeed whats kicking me into FMEM?
    Can I just raise those over my load limit and be ok?
    The MCT is really pushing my comfort zone, it's the stock intercooler and it's a pretty hot day.
    Thanks for any help/suggestions!
    v2.hpt
    log2.hpl
    Jun 2019
    Wisconsin
    295
    Yep, dummy... Revamped a few things, pulled some stuff from the Focus RS... Still was going into FMEM.
    Logged some more, dummy moment... Combustion stability limit was what I was hitting.
    Torque source limit is still comb. stab., but at least it's not going into FMEM.
    *APPEARS* to be able to hold 18-20PSI for as long as I'm in it and feels more or less like the FP tune, though it's a bit more aggressive on the driver demand torque table.
    Happy camper for now. lol
    log5.hpl
    v4.hpt
    Jun 2019
    Wisconsin
    295
    Lost the log that goes with this tune, feels like it's making good clean power.
    I can watch it adding timing while in boost (tops about 23PSI), so it's not knocking on 93 pump gas, though I wouldn't expect it to, since I haven't touched timing.
    The problem I'm having right now, is my OAR (octane) isn't changing at all, it's always 0 in VCM Scanner as well as ForScan.
    Does anyone know if there is a criteria that needs to be met in order for it to start adjusting?
    I'm still waiting for the catalyst readiness monitor to complete, other than that, I have no codes at all (current, history, or permanent), the monitor is the only thing I can think of why it's not adjusting.
    If I can get it to start adjusting to the gas, I can get out of the nominal LSPI limit and make more power... Timing is already using borderline, it's just the air load limit that I'm fighting.
    I know I could just raise the limits more, but I would like to somewhat work with the factory safeties, just in case.
    Edit:
    Found the log file
    Jun 2019
    Wisconsin
    295
    Even though I feel I'm just talking to my self here... But can someone please explain this to me?
    First pull from 1:50.566 to 1:51.676 and the next gear pull from 1:52.326 to 1:55.036 (1-2 gear, I think) felt really good, and aside cylinder pressure limit on spark and DD in combustion stability/torque airsource limit in popcorn, all seems pretty normal, though air load is far from desired load. I'm going to guess that's due to combustion stability, which I can't seem to get around, unless there's something that's missing from the 2.3 Mustang definition.
    Where it gets weird, is a 3 gear set from 8:25.411 to 8:32.471 (2-3-4 gears, I think), the numbers aren't much different, other than coolant temp being fully up to temp, but now I'm getting insufficient fuel limits in addition to combustion stability and popcorn, but in the last gear change, it's going into part pedal/part throttle in the middle of the pull! WTF?
    Is there something weird that occurs when only flashing the calibration where issues get compounded? Should I try doing a full flash write?
    Also, how accurate is the injector duty cycle? I think the highest number I saw was about 30%, correct me if I'm wrong, but that's no where near running out of fuel. If there's a way to correct this, that would be awesome.
    Sep 2019
    3
    With your octane modifier showing 0.0 and your LSPI Lo Effectiveness being stock, I would guess you're hitting a load limit blended between LSPI Lo and LSPI Nominal. But I'm just learning ecoboosts myself so I could be way off base. I don't know if a LSPI limit would effect Desired Load in the log or not.
    With regard to fuel, you got to remember that the injectors on a DI engine can only squirt during the intake and compression stroke, and even then only after the exhaust valve closes and before the spark plug fires. Your current injection timing clips limit you to about 220 degrees crank angle (or 30% of the engine cycle), which at 6000 rpm is right around the 6 ms pulsewidths you are running so your injectors are definitely close to being maxed out as the tune currently stands. You can play with rail pressure and the injection timing to deliver more fuel if your HPFP can support it. Log fuel rail pressure desired and actual so you can see when your HPFP starts tapping out.
    Jun 2019
    Wisconsin
    295
    Thanks for the insight, that makes sense now that I think about it. I'm used to port injection, didn't really matter when you spray, just how much.
    The octane adjust has been an issue as well, it's *never* moved from 0, I'm running 93 and never see any knock, so I'm not sure why it won't change.
    I do still have catalyst monitor incomplete, that's the only thing I can possibly think of that might be holding it back.
    But from what I understand, the LSPI lo table would be used on positive OAR numbers and I should only be seeing nominal, unless there's some calculation jank going on.
    I guess one way to find out would be to copy and paste nominal on to lo and see what happens.
    Sep 2019
    3
    I think knock mode has to be set to global rather than per cylinder for OAR to become active but I'm not sure.
    Below the LSPI load tables are the blending factors which determine the weight of the load tables. There's two active influencers here: the octane modifier (which is fixed at 0 for you it seems), and then the preignition modifier- which I know absolutely nothing about where it comes from or how it's calculated but it could be a contributing factor for you. On my SHO I've only modified the High LSPI table and left Lo and Nominal at stock levels without any issues yet. But I have global knock and my OAR stays at -1 which pushes the ECU towards using the High table.
    Jun 2019
    Wisconsin
    295
    That would kinda make sense for per-cylinder vs global.
    It would be easy enough to test, though the Focus RS and other Mustangs use per-cylinder knock retard and they adjust OAR normally... Could be the out of date programming on my ECU too (still the original version that it got from the factory), I donno.
    I'm still betting that it's because of my cat monitor being incomplete, I've seen other ECUs do odd things when they're still waiting for a full drive cycle to complete.
    I just don't drive the car for that many miles week to week, so it takes FOREVER to complete.
    Jun 2019
    Wisconsin
    295
    Fixed up the fuel rail pressure and widened the injection duration some more, now it's working quite a bit better.
    It's at least hitting the requested air load now for the most part, I'm guess what's holding back my actual torque from the desired torque is likely ignition timing.
    So gotta get OAR working proper.
    Feels pretty good on the butt-dyno, should do a 1/4 mile pull and see where I'm at... Should be quite a bit better than stock now.
    Jun 2019
    Wisconsin
    295
    Set LSPI Lo back to stock and it definitely appears to be blending partly between lo and nominal, max load I can get was about 2.2 vs 2.4 with all the LSPI tables the same (with >2500RPM @ 2.4 load).
    So even though OAR is dead 0.0 (should be straight from nominal only), it's still sampling the lo table for some dumb reason.
    Been trying to drive a little more to get the emissions readiness to set, but just doesn't want to... I'm tempted to do a full KAM clear and start over, but it took forever to get EVAP to set too.
    Sep 2019
    3
    Cool glad you got that part figured out. I found preignition modifier is available as a channel for my car, you could trying logging on yours and see what it is doing and whether that explains the shift towards Lo LSPI. Mine stays at zero.
    Jun 2019
    Wisconsin
    295
    I do have that PID, I'll have to do some logging with that and see that it's doing.
    More on the readiness saga, Friday it give up and is claiming that I have an issue with the rear O2...
    So I had replaced that and it has had cat and O2 readiness set in the past, but it kept getting reset by overboost codes, then EVAP didn't want to set... Basically an endless chain, until now, it's just cat monitor that won't set.
    Unless the sensor died again, I haven't actually been under there to check it yet, it's been way too hot out this week for me to deal with the minor issue. lol
    Jun 2019
    Wisconsin
    295
    Here's the latest tune, for those interested (no log, it would have been mostly the same as the last one).
    For what it's worth, either A. doing a KAM reset, or B. having "all" emissions readiness set has solved my OAR issue, in just a little bit of driving, it's already at -0.05... So it's moving in the right direction!
    For now, it pulls hard and clean, with OAR working it should only get better.
    I'd say it feels faster than the FRPP tune I had before, only now I can actually have an aftermarket exhaust installed with out overboost codes.
    Never did put any of my mod:
    Generic eBay/Amazon (DNA Motoring, I think) 3" downpipe
    Generic eBay/Amazon (Rev9) stainless stock sized catback exhaust
    Generic eBay/Amazon (DNA Motoring) intercooler, gutted intercooler grill shutter
    Forge 007 diverter valve, vented (no real reason, had it from a VW project, found it laying around, didn't want to waste quality)
    FRPP "cold air intake"
    I need to ditch the CAI, it does diddly squat for IATs, the stock air box is *MUCH* better, especially with heat soak. Just needs a high flow filter installed.
    Yeah, it's cheap stuff, though the intercooler is actually pretty decent quality, works really well, and I only had to modify one of the mounting tabs slightly (was a tad too thick), no complaints at $250.
    Exhaust stuff is a bit janky, doesn't fit *quite* right, but again for like $350 total for both catback and downpipe, I don't mind a little extra work getting it fit right.
    Downpipe still needs a little bit of tweaking, it occasionally rattles on the trans crossmember.
    Jun 2019
    Wisconsin
    295
    Latest tune for those interested.
    Currently reliably hitting 2.4 air load, still seems to be pulling more throttle than I would like (apparently due to combustion stability limit?).
    Should get gain more power via octane learning, just like factory.
    Jun 2019
    Wisconsin
    295
    Decided to go back to the drawing board and start from stock again, mostly ended up back where I was... Kinda.
    Did some more reading in old threads, suggestion was made to adjust wastegate base duty to reduce the ECU's tendency to close the throttle to control boost. Works really well, feels much better.
    In the first log snip, the logged torque was a little soft, second log looks really good; holds a really nice and fairly consistent torque through the pull. Third log was a quick pull like the first, torque is up quite a bit, not sure why, maybe.
    I need to do some more fine tuning on the wastegate tables though, while the torque is pretty flat, I could feel the boost surging as it crept up to 25-26PSI from 20. Not alarming, I'm expecting up to at least 26PSI, but it needs to be calmed down a bit.
    Maybe a little higher wastegate proportional gain, to try and drive it harder to target? I'm not sure.
    Jun 2019
    Wisconsin
    295
    Been awhile since I put an update in here... Attached where I'm at right now, everything is actually running really well.
    No real issues and making great power on stock downpipe and a single 3" exhaust.
    Though I desperately need a bigger HPFP, I probably should back things off some just so it's not stretching the fuel budget so thin.
    Also a slightly better turbo would be nice, I'm pretty sure I have this stock turbo completely maxed out.
    Things I would still like explanations on:
    Why throttle angle source = torque reduction < driver demand?
    Why driver demand limit source = combustion stability?
    Is this simply a fact that driver demand is producing a load number that it can't meet?
    Even on the stock cal, it still gives those, so it's obviously not limiting things, but other 2.3 Ecoboost strats don't do this (Focus RS and I think Ranger/Mav).
    Mar 2022
    Indiana
    2,951
    Really nice job and thank you for posting your progress.
    For the throttle dip you could try setting popcorn to 0 at Electronic Throttle Air Limit Sources. You've already tried disabling combustion stability so might as well do this, too.
    I see you enabled optimum power thresholds. Also add that in at Mapped Points Configuration and Snap to Point. Wondering what effect it's having that your speed density tables aren't filled in for OP?
    Power enrichment is set to come in at 70% pedal. Might want to set Electronic Throttle Pedal Pos WOT Start to 358 and End to 512.
    Jun 2019
    Wisconsin
    295
    I believe in sharing tuning knowledge, it shouldn't be some mystic dark art magic.
    I get that people make a living doing this, but I feel that's more of a skill of how you apply that knowledge and not just simply knowing it.
    I've been meaning to see what the effects of pedal position WOT start/end params would have, I see people changing them, but no real explanation as to what/why.
    The description in the editor says it will ignore driver demand, does that mean it will just try to make as much power as possible (up to whatever the next air load limit is)?
    I seem to recall that I tried switching off popcorn in the air limit source table and it didn't do anything for me, but I can it try again.
    The OP thresholds I did in hopes that it might use the OP spark tables, but then realized that it won't go into OP until the mapped points are set and I didn't want to do that until everything else is set up.
    Just never been total sure on how to go about doing that.
    Jun 2019
    Wisconsin
    295
    Made pedal pos WOT and air limit source changes, pretty noticeable... Indicated torque is now over 400 for most of the pull. It'll probably settle down a bit after some more driving, as things re-learn.
    It started snowing slightly today and the ground is wet... Spinning tires at 40 isn't fun, so I wasn't able to get a really good pull.
    Now I definitely need more fuel.
    Mar 2022
    Indiana
    2,951
    Totally agree about the sharing part.
    If you look at your log your vct is following the OP cam angles. It's just not being indicated because you don't have OP set to 1 in Mapped Points Configuration. I was wondering if when set up that way the cam angles would go OP, but the spark and torque models would be off and cause "non-optimal optimum power" lol.
    Occasionally you'll see Pedal Pos WOT Start/End set up from Ford, such as on the Mustang GT350 and some Mustang GT's. You'd think it wouldn't work without Pedal Follower enabled, but that's how it's configured. Odd thing is that sometimes the Ford strategy sets the range between like 90 and 110% pedal. WOT End can't physically be reached, so idk the logic there.
    It's really amazing you're making that much power out of a 2.3.
