Changed fuel from 91 to 95 .
My car is already tuned on 91.
Will it cause issues or it is ok ?
Because you know the lockdown issues.
My car is Commodore ve ss A6
6.0
Cammed with full bolts one.
Your input are much appreciated.
6.0
Without knowing your current spark curve or if the engine's fueling is correct, I'm just speculating but, if you did not have problems with knock retard when burning 91-oct fuel, you may be able to calibrate a more aggressive spark curve at high throttle openings or wide open throttle.
Hib Halverson
Just Another Tuner in Training.
Post tune and WOT pull log
