Electric fans
I have a 2006 lq4 swapped into my 67 c10, I do not have a/c in this truck. I recently wired my wideband into the a/c pressure sensor to log my afr's. My problem is now my fans are turning on or off at weird times, I see in the tune that there is enable and disable pressures for the a/c, which is probably what is turning my fans on and off. I was wondering if anybody has come across this and is there a way to get this working just on coolant temp with my wideband coming in through the a/c pressure sensor
That is funny. Have you thought about using the EGR input instead?
Set the enable pressures for both fans to max. And in the A/C tab, set 'Type Fitted' to 'not fitted'.
