Results 1 to 3 of 3
Thread: LT1 6.2L E92 How to Control Fan Relay For Swap
    Tuner in Training JBMRACING0105's Avatar
    Oct 2017
    USA
    24
    I have done several Gen 5 LT series engine swaps with the E92 controlling a fan relay instead of having to utilize a PWM fan. Typically just setting the Hz frequency to 1200Hz holds the relay closed letting the fans come on.
    However, today I am having no luck. The factory PWM frequency setting is 100Hz and no matter the change I make in the tune, the signal across the relay remains 100Hz not the 1200Hz I set it to.
    Any ideas?
    Mar 2021
    Saskatchewan
    5
    Quote Originally Posted by JBMRACING0105 View Post
    Any ideas?
    It says to set at 128hz in the editor. Have you tried this? I wonder if 1200hz is out of range for the setting?
    Arizona
    239
    Interesting. I just had a restomod with the same issue. Something must have changed because the last one I did, also had the same issue. The shop ended up having to add a thermostat to the Efans just to get the swap completed. Anyone else experience this lately?
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
