Results 1 to 1 of 1
Thread: WOT delayed or While WOT pcm change to Closed loop
    Feb 2020
    38
    Exclamation WOT delayed or While WOT pcm change to Closed loop
    hi guys,,
    i have been working from a while with "panther platform" never had any issues
    only in this car 2011 Crown vic i can't figure out whats wrong with it
    "WOT enrichment"
    the car delay sometime going to into open loop (WOT) or while WOT switch to closed loop(0.950 lambda) even TPS shows 76.1% which means
    Fully open
    No DTC codes and throttle responses very laggy Sometime
    i noticed
    -Accelerator Pedal D when WOT delay happen seems lower percentage than normal
    -switching to CL at WOT : the Accelerator Pedal D percentage start decease
    i tried to lower Pedal POS WOT start about 10% no help
    here is logs
    thanks for help
