Hello everyone!
I feel as if my MAF cal is correct, the car will start and idle. LT fuel trims are near 0 and ST fuel trims are withing 5%....
I cannot really move forward with calibrating the throttle body, because it goes into engine fail safe mode as soon as i write the tune. I have set up a wheel torque error chart in the scanner so that i can log the error, but i cant even rev the car currently, there is no way id be able to log it due not be able to drive.
My starting point is a calibration that the car came with which had the KB 2.8 and this throttle body on there.
In all honesty, im not sure if my maf cal is correct either, because of the engine failsafe mode error i get as soon as the tune is written. sarims first start tune.hpt
I have attached what im starting with in hopes that someone can see where im messing up.
Thank you in advance for any and all help! I love this forum!
