Results 1 to 18 of 18
Thread: 2018 f150 3.5
    Tuner in Training highpsi's Avatar
    Nov 2009
    24
    2018 f150 3.5
    Hi everyone,
    What I've got is a 2018 F150 with a 3.5L. This is my personal truck, I'm actually a GM guy but decided to try a change and I bought this new. I've since started with playing with it, but have zero experience with the EcoBoosts, or Ford at all. I've upgraded the charge cooler, and added an intake kit. I manually measure and fill the tank with an exact E50 mixture. After playing around my best so far is a 13.1 @ 105, which I'm pretty happy with. But I know there is probably a lot left on the table. I'm puzzled why in 1st gear of the line my boost numbers never break above stock numbers. Does anyone have any suggestions for ignition timing? I feel like I'm struggling with ignition the most. Any help or suggestions is appreciated.
    Aug 2010
    215
    Quote Originally Posted by highpsi View Post
    Hi everyone,
    Not sure what weight and trim you have, but 105 MPH is moving.
    Theres a few limiters still in place in the tq management area. The max tq vs gear. It might be holding back power.
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Hi everyone,
    Try this one
    Jul 2016
    613
    @highpsi Why did you increase your inter cooler volume that much?
    Nov 2009
    24
    Didn't even see that one, thanks for pointing it out!
    Nov 2009
    24
    Thanks, much appreciated, I'll give it a go.
    Quote Originally Posted by LastPlace View Post
    And on the charge cooler, the new one is well over double the thickness and end tanks are larger too, so I just roughly doubled the factory size of 15.5L up to 30L. I couldn't find a spec for actual volume anywhere. Do you think I should back it down?
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    227
    What you can do is multiply it by 1.75, and fine tune it from there. at 1.75 your just bumping it up 75% from stock volume.
    Jul 2016
    613
    Which intercooler are you running?
    Nov 2009
    24
    Garrett 870702-6001
    Jul 2016
    613
    Garrett 870702-6001
    I would multiply by 1.5, you can also call Garrett and see if they can give you the exact volume over stock.
    Nov 2009
    24
    I just went and looked on their website again and they list that it's 83% bigger than stock, that spec wasn't there when I bought it.
    Aug 2010
    215
    I also just noticed that your 'Inferred Octane' is only 87.7.
    Was it ever at 91? Should be, with E50. Your OAR is probably '0' and you're not getting all the timing out of it. Most likely from knocking bringing it down.
    OAR should be -1.00 and inferred octane should be 91 with high octane.
    Jul 2016
    613
    Quote Originally Posted by SVT_Z06 View Post
    Was it ever at 91? Should be, with E50. Your OAR is probably '0' and your're not getting all the timing out of it.
    He modified his spark advance limits, his tune will have a hard time getting to -1.0
    Jul 2016
    613
    83% might not equal 83% "internal" volume increase.
    Nov 2009
    24
    Correct I did, I figured I'd rather be in control than it try and test the limit.
    Nov 2009
    24
    Agreed, I did reach out to them, haven't heard back on an official volume yet. But I will for sure back down what I had it set at.
    Jul 2016
    613
    Are you aware that having an OAR of +1.0 causes your truck to run off the Lspi low load tables - OAR 0.0 Lspi mid table - OAR -1.0 Lspi high table?
    edit: Disregard all of your Lspi tables are set to 2.0
