I am very new to HP tuners and tuning in general, i had the initial Tune for my car done by a local tuner to help me get started and get a descent base tune for my car or so at least i thought. I was wondering if someone would offer some insights or even just hints at main areas in my tune i should look to adjust. Right now i am having issue under open throttle, the 6r80 will not shift until you let off and pressure is reduced, then it will shift into the next gear(and it does this for every gear)
I have a 2015 coyote with twin 6766 turbos, bosche 210 injectors, boss intake, fully built 8.8 rear with 3.27 gears.
I have attached my tune as well as a log of the pulls(some channels i didn't have added until just recently so i don't have a pull including them, a lot of tranny ones). I will be hitting the track this friday so will add more pulls after that.
Thanks for you help in advance and i greatly appreciate any information that is offered, I can build the car now i just want to be able to tune it as well!
