air density limiter
I was logging some 6th gear 100% throttle pulls from 1600rpm low load to 2100rpm . I noticed I had hit an air density limiter, when looking at my tune I have baro limits maps maxed out @ 144.973.
Im assuming that was not my issue, then I found my air density governor map, which is stock. is this a map people tend to adjust? Im not one that goes and maxes maps out without doing some research first.
I must of just hit it because I ran a quick calculation and my air density came up @ .165 and the map max out starting at .164
Banned
Yes the air density limiter is linked to the air density governor table.
