I have a 2014 Corvette with the 6.2. We?ve done a lot of work including cam, super charger, upgraded to the LT4 pump and injectors. Deleted Afm and Vvt. It idles tacky and sets low fuel pressure codes. When I did the Vvt delete I changed the phaser gear out and went with the LS3 gear and the Katech delete cover. I?m starting to think the pressure solenoid on the high pressure pump may be opening at the wrong time due to cam position or maybe it?s reading cam position incorrectly because of the gear change. My research shows that the pcm monitors cam position and airmass to determine when the pressure regulation solenoid opens. Has anybody ran into this issue at all?
