Hi I have a 392 with bigger cam. I install a hellcat throttle body and in wot it stop at 76% is it normal ?
Yes that's about right. For some reason these dodge parameters are scaled from 0-5V instead of the actual TB min/max voltages. So 76% of 5V is 3.8V which is the TB voltage when the blade is actually wide open
Thanks a lot !
So I see this question pop up from time to time and my question is why do people log % throttle when editing of the tune requires actual voltages? I log throttle and pedal voltages as it has more meaning than percentage. Or is there a reason for logging percent that I am not aware of?
I'm down with APP yeah you know me.
If in doubt, multiply everything by 1.1.
I used to log throttle % but ended up finding that the scanning rate was much slower than logging the throttle voltage, even if you set the same polling interval for both.
Now I just set up my chart vs time to have the throttle voltage limits of 0 - 3.8V, which gives a nice visual representation of 0 - WOT blade position
Cheers for the tip tbr!
All to familiar! One big rabbit hole there..
https://forum.hptuners.com/showthrea...g-Table-Tuning
62 Biscayne 425/409 SS/D stock class car 10.60s
66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
I would love to pick your brain regarding that @rays04gtx. i have been giving throttle tuning a lot of thought and think there is a lot there not only for consistency and reaction time but maybe for flash? especially if car has a converter. my converter should let this thing flash 500 rpm higher than it was with last years email cmr tune
It’s not a perfect “science” , there’s latency, its not dead on , APS 100% = xTPSv is not perfect, but real world isn’t either. I know with what I do it’s helped, I log APPSv,TPSv&TPS% no need for APPS%(my opinion) I use three gauges sit them beside each other
04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
G3 Hemi Videos
https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
