Hi all.... I did a bonehead move last night in the staging lanes..... in a rush to adjust timing and write the tune before my next run, I loaded the tune with my feet on the clutch and brake pedal. Needless to say, now my car wont start..... no clicks, no fuel pumps, no anything.
One thing I did notice is that the indicator for the security system blinks when I turn the key to run and try to start the car.
When I try to connect to the vehicle thru the scanner, I get the message that says it is unable to connect to the vehicle.
I disconnected the battery, I resynced the the interface, I removed and reinstalled the MPVI2 i the OBD2 port, I restarted the Editor and Scanner - no luck.
Thoughts? Is it bricked or is the security system disabling the ECM? If it is the Security system how do you override it if you can't connect with the VCM Scanner?
