Results 1 to 6 of 6
Thread: weird dynamic airflow problem
    Aug 2013
    australia
    364
    Hey guys I have a weird problem I have not come a cross before. I have tuned a ve commodore ute l98 manual maffless tune, cat back exhaust and OTR and it's doing weird things like the maff is not failed properly. please see log (around 16;50 on log and tune. Cheers
    Jan 2014
    Australia
    1,984
    not sure but its not failed properly, its set to mil on second error should be first error P0101, P0102, P0103, then fail high 2 low 1, high/low counts to 1, rpm min 0, ert and test set to 0, dynamic airflow high/low 8100 8000 (u have 8000 and 100) see how that goes
    Aug 2013
    australia
    364
    Hey mate cheers for that it has worked, admittedly I did forget to set the fail on first error, but have never had to set the other things you mentioned. In saying that I wonder would running a sd custom opp masked the issue and this one is a standard os. Anyway cheers for the help I believe you have help me a few times over the years and I do really appreciate it.
    Aug 2013
    australia
    364
    Dam I jumped the gun it has done it again. I think I might re-tune it on a custom os.
    Jan 2014
    Australia
    1,984
    maby try disabling the cat test also, when SD u should change the max fail 60 to 200 also for the throttle body, if u download the newest beta there are some more torque management settings related to spark and throttle could be worth a check
    Aug 2013
    australia
    364
    Did a full retune with a custom OS about a week ago and it?s been good, I wonder what it could of been. Cheers for the help.
