I am putting a 5.3 into an old CJ7 and I know enough to be dangerous. I have built a bench harness so i could read the ECU into HP Tuners. The downloaded tune is attached. What do I need to turn off to make this puppy start once i have the motor between the frame rails? I have the pedal from the Silverado so i will be using the original pedal and throttle body. Everything is stock, hoping that will make this go easier. I am mating it to a manual transmission so i need to make sure its not looking for a TCM or anything. I am also only running the front O2s as there won't be any Cats or a reason for a second set of O2s.
Any help is appreciated!
2011 Silverado 5.hpt
