yeah thats what I was gonna say next only other thing it can be is load not logging correctly
SCT is garbage for tuning eec-v and eec-iv. If your going to tune it you might as well use tunerpro. It has histograms that dial in the inferred load table, fuel pump voltage table, maf transfer from the o2s, and with a wideband wired in to the egr input it even shows you the wot fuel error to correct the maf transfer. The datalogging on tunerpro is second to none and has an extremely accurate rwhp and rwtq graph that usually matches the dyno within 5 hp. Tunerpro gives you unrestricted access to the full tune so you can even copy pats codes from one ecu to another to swap ecus for a v6 to v8 swap and keep theft, etc... Theres several custom code patches too that are only available with tunerpro as well. Like on the marauders a custom 15x15 spark table and 15x15 knock threshold table. I'm only giving you the basics when you get more involved with it you'll see just how far superior it is than anything else available for the older ecus. All you need is a $250 moates quarterhorse. The software, custom tuning strategy datalogging and even a base tune is all free downloads. You can download it now and check it out if you want. Details-
http://www.efidynotuning.com/started.htm
