Results 1 to 2 of 2
Thread: air density limiter
    air density limiter
    I was logging some 6th gear 100% throttle pulls from 1600rpm low load to 2100rpm . I noticed I had hit an air density limiter, when looking at my tune I have baro limits maps maxed out @ 144.973.
    Im assuming that was not my issue, then I found my air density governor map, which is stock. is this a map people tend to adjust? Im not one that goes and maxes maps out without doing some research first.
    I must of just hit it because I ran a quick calculation and my air density came up @ .165 and the map max out starting at .164
    Banned
    Jan 2018
    Everywhere
    1,772
    Yes the air density limiter is linked to the air density governor table.
