Pull3_map10.hpl
NewMotor_Basetune_V8_DriverDemand.hpt
2012 Coyote A6
I started tuning my TQ table to reduce TQ error and TB blade error, and I've seemed to have hit a limiter. Please know, that this car has a large converter, hence the TQ table tower around the stall speed of the TQ converter.
The issue is that once the TQ tables reach around 650 lb-ft it won't go into VCT OP, and defaults to map point 10 & Fuel Economy/Optimal stability VCT, during a pull. I can change the TQ back to the original values, and the car goes into VCT OP like normal. What I'm I missing?
I'm lost on the root cause, but the I've made decent progress in reducing TQ errors except when it drops into Map point 10. At which point the cam angles stifle air flow and the car falls on it's face--typically LB/min peaks at 50lbs/min. Any help would be greatly appreciated.
Please reference the attached tune and data log.
Thank you
