I have an LS SWAP L94 with a Cam swap that won't stay running. It has an E38 for a 5.3L that has had a tune for a 6.2L loaded into it. It looks like the injectors for some reason are not working after it gets to the initial fire. It basically starts like normal and goes up to a 1500 rpm then immediately stops running as if it runs out of fuel. I am failing the MAF sensor immediately so it should be using the SD tune. The airmass goes to zero which is why I'm assuming why the injectors stop sending fuel. This is an engine that has good compression and is mechanically sound. I've attached a tune file if anyone has any idea what is shutting it down let me know. Thanks!
