Results 1 to 5 of 5
Thread: Idle Torque Tables help
    Sep 2008
    Australia
    80
    RPM error axis, you would have to think the negative values (example -500rpm) are under desired RPM. Hence non neg values are RPM over desired RPM.
    If this is the case why are the table values negative in neg rpm columns and pos values in pos columns, as though they would be pulling torque when you are under your desired RPM. So on and so forth.
    Surely these tables are mis-represented in either the table values or the x horizontal axis?
    Would someone care to explain their take on it. Cheers
    816
    I believe that the rpm numbers represent the correction desired, so they are actually opposite.
    Someone that knows for sure will surely jump in here....
    Nov 2019
    227
    I believe this solid thread has all the info you require in it:
    https://forum.hptuners.com/showthrea...ntrolled-Setup
    Sep 2008
    Australia
    80
    Quote from 06300CSRT8 from the above link. For my future reference. Makes sense now. Cheers HaasExp.
    "The correlation here is as follows: first off the RPM error is opposite what you think in the tune, negative is above idle. So at +200rpms in each of these tables which is 200 rpms below desired idle"
    Nov 2019
    227
    I still confuse myself when I read that.
    So I just write it as:
    RPM Error = desired - actual
