I have a sealed motor 6.1 that is Long tubes and e85 (hellcat inj) only. Car runs great but I can not keep it to stop loping at idle. Every once in awhile the surging will stop.. but it is persistent when in P/N or in D. Even putting the car in Reverse causes as well. I have played with TB Airflow data but not sure if I should keep playing with the 3 TB tables or if there is a fix somewhere else.
ANY and all help is appeciated. I have attached the stock read file, the current file on the car, and a log of showing the car surging. ***In the log the only thing I notice is abnormality in the O2 voltage reading on B1S1 and the STFT of B1 being much higher than the other side. The surge is also noticeable in the AJ 1 log as well.
AJ hellcat inj start up e85 VE 2.6 NN 800.hpt
AJ Surge at IDLE.hpl
AJ 1.hpl
AJ stock read file.hpt
