Results 1 to 3 of 3
Thread: Need some help please
    Jun 2019
    5
    Last night I finished putting the motor back in my car. I have a 2013 Camaro SS with the L99 engine. I went to start it and all the lights and dash come on, but when i try and crank it the power cuts out. I've check all the grounds and all the grounds are connected and in the correct position. I tried and hooked up a Snap On Solus scan tool to see if there are any codes and it cannot communicate with the ecu, could the ECU have somehow bricked itself? I have not touched the tune since before it was running. I currently have a ticket open, but I wanted to get some feedback in the meantime.
    Thanks!
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    Sounds like you may have a bad car battery or you did not tighten the battery cables enough.
    Jun 2019
    5
    changed the battery and the battery cables are tight
