Originally Posted by
flubyux2
I think my idle is maybe 80-90% there using the walkthrough that has been discussed in another thread. I had to reduce the Final Idle airflow alot from what it was. It had alot of correction from over/underspeed. the adaptive idle spark was fluctuating wildly when i first got the car so i disabled it and began adjusting. i finally got the car to idle with ac on and require no spark correction at my target rpm. it keeps trying to idle high and im seeing a few degrees of spark retard to drop from 1000rpm. but im still getting 1100-1200rpm when coasting to a stop and it takes a while for it to drop below 1000rpm. my Throttle Follower Torque table has large negative values to try to trim down the last bit. Not sure if i should keep going further negative or if there is a better table to fix my coast down rpm hang.
LS7, big cam (idk which one), heads, intake, LT's.
Log and tune attached. stock file attached for comparison if necessary.
