Results 1 to 3 of 3
Thread: new to tuning trying to idle
    Jun 2020
    1
    it is a 5.3 with a mild cam <size and stats unkonown> i still have the original computer that was with the motor. swapped a 07 suburban 5.3 to a 2000 silverado. using the stock silverado computer still. i have played with alot of different things and used stuff from here and youtube. i got a tune that somewhat runs the truck but scared of messing something up. here is what i got so far from stock to what i have done. i including a data log and the stock and mod tune i used steer me if you can i want to learn not just have someone make it work
    Apr 2019
    Parts store
    476
    What are you wanting help with?
    May 2020
    11
    If you mean idle issue , do some idle base running airflow corrections in scanner first and see what's happen .
    I do have idle issue myself after I set everything where it should be ; I have some kind of hesitation at idle and initial drive between the idle to 1100 rpm, the rest of rpms runs very smooth thought.
