Results 1 to 2 of 2
Thread: Need a tuner for turbo lfx
    Hey guys, I got a 2016 Colorado 3.6 and I put a rear mount turbo on it. I have been searching for a remote tune but no luck yet. I am looking for someone to do a remote tune. No one here in Hawaii tunes with hp tuner. Here are some of the stuff I put on it
    Sts turbo - rated at 620hp 59mm compressor inducer76mm exducer 68mm turbine inducer with a 68ar turbine housing
    Turbosmart hypergate 45
    Tial bov
    Turbowerx sump pump
    Oil catch can
    2.5? intercooler piping for turbo to tb with a small intercooler
    21/4? hot pipes from engine to turbo with stock cats
    3? corsa exhaust
    1 step colder spark plugs
    Any help would be appreciated
    Jul 2017
    22
    griff, the gentleman who has posted his email address in the attached link may be able to help you as far as tuning the vehicle yourself, which may be the most cost effective, practical and realistic approach under the circumstance. I believe your having a 2016 means you may also have an additional computer challenge to overcome. I'm confident this member can guide you along to achieving your tuning goals yourself. I'm assuming you already have HPtuners, if not, I believe that would be your best start, along with researching the changes that need to be made in addition to input you receive.
    https://forum.hptuners.com/showthrea...r-your-LFX-LLT
