Finally got an answer as to what's going on.
I was on the phone with Circle D and the rep admitted to me not willingly (He suggested that clutches in my transmission were causing the slip) but after some educated discussion that they have hired some new machinists and while machining they had added a chamfer to the input receiver just behind the lockup apply seal. This in some cases once the fluid is hot allows enough to pass bye that apply is not maintained.
I'm guessing they don't want to openly admit this issue because there may be some liability involved. But I needed to know if the issue was actually resolved. Ive never known them to hide something like that and have used them for a couple builds. A bit disappointed. But Ill post back and confirm that everything is working properly once the converter is back in the truck.
Once the fix has been completed im going to call and see if I can get in touch with Chris himself.
That was it. With the rebuilt Converter Im not having any issues with lockup so far.
Did they address the machining issue going forward?
Glad you have your issue resolved!
Yes. its just a few thousands difference.
The camphor was the issue. I did talk to Chris about the issue and there were a very small number of converters that went out with this defect.
This issue can now be identified by logs. I would suggest if you think this is your issue you contact there support. They are now equipped to diagnose this issue.
Not fun for anybody involved but they are doing what they can for me at least to make it right.
Circle D did not know the cause of this issue until troubleshooting the converter we sent back but fixed 3 (if I remember correctly) in total with this issue at this point.
Message me if you have questions. Ill help where I can.
Still going strong.
It’s more then just a few that have had this issue…
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
Have a customer with an FTI and it’s doing some funky stuff too in third… started after the converter swap
14 Gen 5 Viper
Dont worry, the GM converters arent any better these days....or transmissions for that matter. Made alot of money from these 10 speeds lol
