Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Making your, at least 05-06 545RFE into a 6 speed and accessing files with your HPT
    Oct 2021
    Slovakia, Europe
    16
    Hi all
    just trying to do some RFE tuning on a Jeep Wrangler 2.8CRD equipped with 5-45RFE trans
    It uses a standalone NGC controller for the trans.
    HP reads it, but after saving it does not open, fails to validate the file and load definitions.
    Emailed the file to HP support.
    I tend to think it is an NGC3CAN, not NGC4. Original PN is 5094998AB (AC, AD.. up to AF)
    Later model diesel JK with the same trans uses 5150267AC TCM - which is the same part across the whole Jeep/Dodge line of standalone TCMS for RFE trans
    Found this thread about replacing the TCM to unlock the options for RFE
    Any idea please?
    thanks
    paul
    Oct 2021
    Slovakia, Europe
    16
    update:
    emailed my files to HP Tuners. The new VCM Sute Beta v.4.13.261
    now supports standalone 5-45 TCU from a CRD JK
    Mar 2015
    25
    Interesting, I have a 2006 Jeep Liberty KJ 2.8 CRD that uses a similar setup to your JK I believe. I'll have to see if I can get them to add this TCM to their list as well.
    Oct 2021
    Slovakia, Europe
    16
    Quote Originally Posted by elementaltoad View Post
    not sure. KJ 2006 still used PCI bus for communication, with Bosch EDC on the K-line. but you can give it a try. If you do keep us informed please
    Quote Originally Posted by HemiX2 View Post
    This thread is for, at least, those folks that have the early (05-06) 545RFE transmission in "probably" any Chrysler platform that uses this transmission that IS NOT supported by the HP Tuner, and most likely won't ever be. With the help of one of our newer forum members, caulk04 I've done this mod. to my somewhat modified 06 5.7 Hemi Jeep Grand Cherokee Overland (see signature below). I have replaced the NGC3 PCM/TCM in the 06 with one out of an 08 5.7 Hemi Jeep equipped with an NGC4 PCM/TCM that is supported by the HPT.
    It is a relatively easy swap. I picked up a used 08 Jeep PCM/TCM, P/N 05150258AC, operating system P/N 05187311AI and installed it in my 06 Jeep. I can now, after expending 2 credits, access and modify the transmission files in my 06. I have just begun to start messing with it, with caulk04's help, since he knows more about the operation of the 08 unit than I do. So far, I've made the 5 speed into a 6 speed by inserting 2P into the shift schedule (requires just a flip of a switch in the files) and have started tinkering with the rest of the up/down shift schedules, torque management settings and, hopefully, the torque converter slip settings. Once you pick up an 07-08 PCM/TCM, all that needs to be done is to install it using the FSM procedures, change the vehicle VIN and PCM odometer reading to those in your original PCM/TCM, clear a bunch of codes and, hopefully you'll be on your way.
    I also have two Hemi LX's with NAG1 transmissions and, I will say that setting up the 545RFE will be a lot more difficult than with the NAG1's, because almost all the tables, histograms and item headings are considerably different and there is a lot of other stuff that I don't understand or am not familiar with. Hopefully, some folks that are more knowledgeable than I (that doesn't take much) will be able to figure them out and post them up so we can all finally get our 05-06's to work the way they should.
    My thanks again to, caulk04 for giving me the huevos to attempt to this mod. Without his input, I'd still be procrastinating about whether or not I should try it and/or whether or not it would work. Let's all work together on this and maybe we can make these 545RFE's work almost as good as we can the NAG1's.
    Hi, how it's going with the mod 3 years later? I have a 2005 WK 5.7 HEMI with some problems that could be in the PCM. I have active P0100 error often only with hot engine and key in "on" position. Messages of "4x4 service", "electric brakes" "check gauges". And the engine starts but it stalls. Then if I put the key in "off" and start the engine from the "off" position without stopping at "on", everything is perfect, without errors... And P0100 is already "historical".
    After reviewing and cleaning connections from CAN-C, I was thinking of change the PCM, and take profit of the change putting a 08, to gain the possibility to force 2P with selector.
    I've read your post and I wonder if all is good or you had some kind of problem or error code after swapping the PCM.
    Thanks in advance.
  6. #26
    Tuner in Training VPP1776's Avatar
    May 2023
    Sparta, WI
    36
    Just to clarify, the 05 and 06 NGC3 equipped vehicles don't need anything changed in the harness to accommodate the NGC4 controller?
  7. #27
    Apr 2023
    Sofia, Bulgaria
    36
    Quote Originally Posted by VPP1776 View Post
    No, you don't change anything. Just made a 07 Commander 5.7 NGC4 swap into 06 Commander, previously with NGC3. When the NGC3 PCM warmed up, the engine started to shut down from time to time with immobilizer lamp flashing and several other DTCs. The swap made all this go away. You only need to program the VINs (I did both original and current), and eventually reset all adaptables and do a trans quick learn.
    It now starts better (faster and clearer) and shifts better (as far as I know, the shift points are different on NGC4). This brought a big smile on customer's face.
  8. #28
    Mar 2024
    Central Indiana
    8
    Great thread. Following.
    Currently working on a 2005 Jeep Grand Cherokee Limited with 5.7 HEMI
  9. #29
    Oct 2023
    3
    would like to see the tune file on the trans side
  10. #30
    Apr 2023
    Sofia, Bulgaria
    36
    No tune is needed. Get a 07-08 PCM from WK or XK (not 2009-2010, theese are different for Eagle with VVT), program the VINs, eventually program the SKIM if enabled (both done with AlfaOBD/JScan, you will eventyally need the PIN - also can be found with JScan) or disable it, and it just starts and runs.
  11. #31
    Sep 2024
    What would I have to do if I have an 04 dodge ram 1500 NGC3 and want to go with a NGC4?
  12. #32
    Apr 2023
    Sofia, Bulgaria
    36
    04 RAM is with early non-CAN NGC3, and I dont think the swap with 2007+ CAN NGC4 is possible.
  13. #33
    Sep 2024
    oh okay, I?ve seen people say swapping the pcm out of my 04 ram for an 05 pcm is better for tuning, is that true?
  14. #34
    Oct 2021
    3
    I got a 05 WK 5.7hemi and 545RFE with the autostick shifter PRND then +/- for autostick. i got a 07 durango pcm laying around say transmisson but it had a column shifter think it was PRND21? can i run that pcm on the trans and have the auto sick functions? this is swapped in to a 85 dodge truck so any warning lights im not worried about.
  15. #35
    Apr 2023
    Sofia, Bulgaria
    36
    Quote Originally Posted by MoparStu6.7 View Post
    Probably you can run this PCM, but it must be reprogrammed with WK 2007 or 2008 OS, VIN programmed and SKIM cleared in order to adapt to new vehicle on the first start. Then you will see if something is missing.
    Another thing is - 2005 5.7s have HV cables to half of the plugs - the same ignition coil drives one plug on each engine head. 2006 and later are coil-on-plug and a coil drives both plugs on the same cylinder. I don't know if this matters.
