Results 1 to 10 of 10
Thread: LT5 Throttle Body Tuning e92
    Jan 2020
    15
    I was curious if anyone had any new information about the lt5 throttle body tuning. Have the max area maps been created yet? And is torque management... reliable with it yet?
    Or if there is somewhere to find what is in the e99 ecu for the throttle body?
    Just trying to for-see if the lt5 throttle body would be a mistake over just the 87mm.
    Any info here would be fantastic.
    Mike
    Aug 2009
    Calibrating
    3,376
    Scaler is around 5500... but honestly I don’t even change the scalers on gen 5 ecms anymore
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2003
    South FL
    1,375
    You will need to edit Cranking Airflow, VVE and Virtual Torque.
    [email protected]
    Owner/GM Calibrator
    Dec 2015
    Miami,Fl.
    290
    If you're installing it on a zo6 don't bother changing anything besides re scaling the MAF for the increased airflow.
    2023 Ford Maverick 2.0T AWD
    May 2003
    South FL
    1,375
    Quote Originally Posted by HeavyChevy305 View Post
    You don't have any issues with idle Spark Advance by only changing the MAF?
    [email protected]
    Owner/GM Calibrator
    Aug 2014
    Central, LA
    737
    Some will randomly want to idle with negative timing. No big deal to fix just decrease negative spark areas in idle zones in the virtual torque tables to bring the spark up and throttle will close down to reach torque. Definitely worth it imho.
    Dec 2015
    Miami,Fl.
    290
    Nope. Even with a Katech 103 it idles perfectly fine timing n all.
    Dec 2019
    DFW, TX
    124
    ive tried playing with the tables mentioned and i still cant get my mamo ported lt1 tb on my 18 ss 1le to stop cold start surging the first minute or so. any tips?
    May 2003
    South FL
    1,375
    Quote Originally Posted by ShaneB View Post
    Cranking Airflow needs adjusting downwards to stop the flare up but it shouldn't be surging at all. A couple of things to try, #1) pull the negative battery terminal for 5 minutes, then reattach and crank car while cold and let warm up at idle without ever touching the accelerator pedal. #2) and this is an odd one but worked for me on a Gen 6 Camaro, I transferred the original throttle body motor over to the ported TB and the surging completely went away. No idea why this can sometimes be a fix for this but it is.
    If neither of those help, then you likely need to have Tony swap out your TB because it was over ported in the wrong(sensitive) area.
    [email protected]
    Owner/GM Calibrator
    Dec 2015
    Miami,Fl.
    290
    I'd return it for another one.
