Results 1 to 10 of 10
Thread: V2 CTS V TH400 Swap Help Request: No Dash speedo reading
    Jun 2017
    6
    Looking to see if someone can point me in the right direction. Just recently swapped trans on 2011 CTS V. Went from a 6L90 to a Manual Valve Body TH400. All gauges read correctly except for the dash speedo. It switched trans to manual and disabled the VSS. I get nothing on the speedo. When I log in hptuners, I do get a speed reading for driven and undriven wheels. Is there a way to direct the speedo to read from the wheel sensor? Would flashing in a manual cal fix the problem as I don?t think the M6?s had a VSS. Appreciate any guidance on a possible fix.
    405
    2,288
    Should be able to do something similar. I did this on a 98 Z28 that swapped to a T-350.
    https://ls1tech.com/forums/automatic...eedo-work.html
    And M6s had a VSS
    7,451
    The auto trans ECM OS is expecting to see the VSS come in over serial data from the no-longer-present TCM. The manual trans OS has the VSS wired direct into the ECM.
    Jun 2017
    6
    What is the speed sensor data source on the manual OS (VSS,Wheel Sensor)? It looks like the wheel speed sensor is providing a speed input. What problems would I encounter in flashing a manual OS over my Auto OS? Note: its a Gen IV V8. Thanks in advance.
    Aug 2010
    Detroit, MI
    926
    I was able to tie in a TH400 style reluctor on my Colorado with the T42. Just needed a 10k resistor to shunt some current from the sensor to ground, otherwise it saturated the VSS input on the TCM. That's an option if you wanted to not get rid of the TCM and have it work like stock.
    Jun 2017
    6
    The TCM was removed as it was part of the OEM 6L90 that was replaced.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,856
    Most wind up running a manual OS. I have these OBD2 pass through devices I made that could potentially replicate a T43's communications, pull speed from a wheel speed sensor, and convert it back into a CAN message the ECM can use. The problem is the time to develop that is going to be expensive.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2017
    6
    . When running a manual OS, where does the speed signal come from? VSS or wheel sensor?
    Mar 2008
    St. Louis, MO
    4,856
    You need a simulated VSS. I made a module for a guy one time that generated one based off of a wheel speed sensor. It just crapped out a variable frequency based on rear wheel speed. He got it to work.
    Jun 2017
    6
