Results 1 to 7 of 7
Thread: 09 Challenger Stuck WOT
    Aug 2016
    Brooklynville
    11
    Need a little help, tried a few changes with no difference. Procharger D head low boost (5.5psi) throttle hangs after 5.5k.
    Aug 2010
    Detroit, MI
    930
    Need to log calculated MAP, throttle flow, idle torque, throttle adaptives, torque adaptives, phi adaptives...anything airflow related that you can find.
    Aug 2016
    Brooklynville
    11
    Any ideas? Clicked it off at 5500.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    584
    try simple adaption for throttle off....may help, but no perfect soluion.
    Aug 2016
    Brooklynville
    11
    Quote Originally Posted by f.creek-ranch View Post
    Tried didn't help but Thank you.
    May 2018
    Germany
    584
    Maybe it has to do with your throttle body airflow model.....and feedforward.
    try to scale it ...seems a little to narrow in high position...
    Mar 2018
    Illinois
    873
    I am no pro but looks like your large range (yellow curve) deviates from your main airtable.
    From info in these threads you want to keep all three tables essentially identical.
    https://forum.hptuners.com/showthrea...hlight=airflow
    https://forum.hptuners.com/showthrea...nse-with-a-S-C
