Results 1 to 5 of 5
Thread: Injector Duty, Torque and Cyl Airmass SPIKE while tuning VVE
    Jan 2020
    27
    Exclamation Injector Duty, Torque and Cyl Airmass SPIKE while tuning VVE
    Anyone have any input on this? Everyone I have talked to has never seen it before.
    I am dialing my VVE table - MAF is turned off.
    This is a C6 LS3 with just headers.
    I see no spike in my VVE table.. Completely perplexed as to what would cause this.
    Duty is 200%
    Cyl Airmass is 3.39
    Torque is around ~1600ftlb
    This has happened 3 times. Finally caught it on a log.
    Tune attached.
    Step 5 new zone boundries.hpt
    I’ve got a very similar issue. Did you find the culprit?
    Dec 2020
    5
    Can you post up your spark map? You could use a whole lot more ignition timing but this looks like a misfire/ cam bucking. The other thing I would note is you?re at 100% throttle but only 89kpa. Do you have a dirty air filter or at high altitude?
    Jun 2014
    Boulder, CO
    201
    Your fuel pressure across the injectors table is almost flat -- do you have a MAP referenced FPR? But I don't see that affecting the crazy air flow spike! Your trans output max torque setting is 12,084 lb/ft, I thought the max value the ECU allowed was 6042. It's perhaps suspicious that it's exactly twice 6042? But I've no idea if that could cause the reported airflow spike, either. And I agree that the timing maps are very conservative, even for a boosted engine.
    Dec 2008
    on the Dyno
    1,825
    It's in your VVE...
    If you add MAP axis in 1kpa increments youll see a huge increase in GMVE from 90kpa -> 89kpa. Also zero out the prediction coefs.
    Located in Central Kentucky
    ShorTuning
