Hi Folks,
I am not a tuner but have a problem that the tuner I'm working with is "stumped" he says
The issue in the Log 46 and video 42/46 shows the problem between 5th and 6th gear change and he adjusted it some and it got better in the 2nd adjustment in log/video 47 but still has a slight issue.
Its only 5th to 6th gear the problem happens 2 out of 3 times
Now all other shifts in the mustang 2019 gt 5.0 are fine and it has the procharger HO kit so you know what its running
Maybe someone here has seen this issue and can point or give a solution to what to do. Its been 3 months and this is getting kinda depressing to deal with and I can't do anything or suggest anything but maybe you guys can help me pass some info to him on what to do.
If you look at the short videos its very easy to see it drop throttle or something
This all started once he flashed the new update to the transmission and increased the tq output he said.
Any help will be appreciated Thanks folks
Should I cross post this in tuning also ?
#47
#46
