Hey Guys,
I'm trying to help a local shop sort out a couple of projects. One is a 2016 Z06 A8 car. It goes into REP Mode when at high boost/rpm.
I suspected I would see a P0068 or something of that nature. However, I didn't find any codes.
I did notice that P0016 had been disabled. I enabled that code and it popped up pretty quickly. It's disabled again now.
Just a little info on the car. On a good pull, when it doesn't go into REP Mode, it peaks at around 240 kPa. It has a triple nozzle meth kit (3 M15 Nozzles).
I did notice in this datalog that the Peak and Max engine torque converge under boost. I'll increase Peak and see if that helps the throttle to be more consistent.
It just seems odd that there is no DTC present when it goes into REP. Will you guys take a look and see what's up?
Thanks,
Kevin
2016corvettez06autoHuntermod.hpt
z06red4.hpl
