Results 1 to 7 of 7
Thread: ivalid vin/os pair??? help me plz
    Tuner in Training jeffreycobra's Avatar
    Jul 2020
    North West Indiana
    17
    Question ivalid vin/os pair??? help me plz
    so I got a new ecm for my 04 yukon l59 5.3 which originally had a p59 ecm on OS 12585950, and the new p59 ecm is out of a 2005 escalade and it's OS is 12592618. i can change this one to 5.3 engine, but what else is needed to change to run my yukon? I know I'll have to do a write entire on my bench harnes like i plan on doing but I'd like to put my vehicles vin to this ecm. Is there any suggestions you guys have?? I know I'll have to license the yukon to be able to write to it but i would like to put my vin and whatnot on it.
    2004 GMC Yukon L59 AWD 4L60E. E85
    13,565
    Flashing it with the OS and VIN you want with a GM tool would save you several credits. Then it would be plug and play.
    Jul 2020
    North West Indiana
    17
    I dont have one otherwise I would so sadly i had to buy another 2 credits to license the vehicle.
    Jul 2020
    North West Indiana
    17
    anyways, i am about to write this ecm. Should i just write calibration only, and disable vats for now so itll work with my yukon?
    13,565
    If it was me I would just take the computer you have and use the compare feature. Then copy over all your yukon data into that escalade computer. Would take all but a few clicks of the mouse to copy the engine data over.
    Doing a VIN/OS swap would create a new VIN/OS pair and likely make you license that single VCM license again. The VIN doesn't mean anything anyway, makes zero difference in how the vehicle runs.
    This would be the best case here. This should work so long as there isn't huge differences in the TAC module and APP between 2004 and 2005. That could make it run weird I suppose or go into REP.
    Jul 2020
    North West Indiana
    17
    thank you for the information and help lol so i can just simply write a previous tune from my yukon onto this ECM but wth my engine data in place of the 6.0's
    13,565
    Well, you can but not the way you typed it out exactly.
    Just take your new computers file that I assume you already licensed ( the 05 computer), then open your previous yukon tune with the compare feature. Click compare again and click view comparison log. Collapsed all the boxes in the new window and right click the engine icon, then copy over all differences. Now that 2005 computer has the yukon engine tune in it.
    Then you can flash that file in. Do not write your yukon file into the computer, just copy the data over.
