Results 1 to 4 of 4
Thread: Shut off torque management when braking
    Jul 2020
    2
    Yes I know this has probably been asked many times!
    I had no problem on my 2002 z28 Camaro disabling all of this.
    But on my 2012 Camaro SS, I cant seem to get down what I need to tune out or in in order to get my automatic to do a burn out.
    Is the setting I need to modify the Engine->Torque management-> brake torque limit?
    Under Trans->Torque managment I have disabled the TCC limit / TQ reduction and set max torque
    Any help is appreciated!
    Thanks in advanced!
    I have attached my tune as well
    13,559
    Sure, give it a try.
    Don't stomp on the brake either, it may not be able to overcome the friction of the pads.
    Side note as well, your PE is way to fat for a NA engine.
    Jul 2020
    2
    Oh I am barely pressing on brake. The minute there is any pressure on the break pedal the motor goes into the power down and will not rev over 1100ish.
    Roger that on the PE. The tune in the car is how I bought it. I am thinking someone was playing around and wasnt sure what they were doing. IMO.
    Feb 2015
    Perth, Australia
    974
    disable brake tq managment and max out table
